Creating Kx kdb+ Output Connector
Allows periodical dumping of records from a Kafka topic into a Kx kdb+ connector.
1. On the Data Source tab, select Output > Kdb+ in the Connector drop-down list.
2. Define or select the following properties:
Property |
Description |
Host |
Kx kdb+ host address. |
Port |
Kx kdb+ host port. Default is 5001. |
TLS Enabled |
Ensure to check if you have started q with TLS only. |
User Id |
The user Id that will be used to connect to Kx kdb+. |
Password |
The password that will be used to connect to Kx kdb+. |
Table |
The source table. |
NOTE |
These properties can be parameterized.
3. You may opt to use the toolbar to complete the data source definition.
4. Click . The new data source is added in the
Data Sources list.
