[4] PCLI: Command Utilities for Panopticon
Panopticon Streams is supplied with a command line utility PCLI.jar.
Export Data Sources
THE PCLI provides functionality to export data sources from one or all workbooks in a directory. The exported data sources can be uploaded and used directly by Panopticon Streams.
Parameter |
Description |
Required |
-w, --workbook |
The name of the workbook. |
Yes (or -wd) |
-od, --output-directory |
The output directory where the data source will be exported to. |
No |
-wd, --workbook-directory |
The directory of the workbooks folder. |
Yes (or -w) |
-dd, --data-directory |
The directory of the data folder. |
Yes |
-l, --license-file |
The path of the license file. |
Yes |
Example 1: Export data sources from a workbook
java -jar pcli.jar exportdatasource
-w "C:/vizserverdata/Workbooks/VizGuide.exw"
-l "C:/vizserverdata/PanopticonLicense.xml"
-dd "C:/vizserverdata/Data"
-od "C:/streamsserverdata/CEP/Datasources"
Example 2: Export data sources from all workbooks example
-wd "C:/vizserverdata/Workbooks"
Where:
q C:\vizserverdata is the AppData folder of Panopticon Real Time
q C:\streamsserverdata is the AppData folder of the Streams server
