Cut, Copy, and Paste
Cut, copy, and paste objects using standard keyboard shortcuts, the context menu, or the Edit menu.
| To | Do this | Note |
| Cut |
| Copy |
                                You can copy an object by holding down Ctrl as you drag it. (This only works if you have Move selected in the Preference dialog under Modeling Space.) |
| Paste |
                                The copied object is pasted on top of the original object.
                                    Press M to use the Move tool to move the
                                    copied object. Any update to the source object made before the
                                    paste event in construction history will be made to the the copy
                                    as well. Note: Paste is not available when
                                        trying to copy an assembly. You must use Paste Instance or
                                        Paste Without Reference.
| Paste Without Reference | Right-click in the modeling window or Model Browser, and then click Paste Without Reference. | If you paste without reference, no updates will be made to the copy, even if you roll back and make changes to the history of the original object. |
