Specify a unit system for both input and output.
In the Project tree, right-click on Units.
In the dialog, specify the Units system.
Click the Input units tab.
Use the drop-down menus to specify desired units.
Click Output units tab.
Use the drop-down menu to specify desired units.
Under Output format, choose Scientific,
Engineering, or Concise mix
numerical output format.
Note:
With Engineering format, setting too few digits after the dot may result
in zero quantity output values. For example, the number 0.0000056
specified with Engineering format and 3 digits after the dot will be
displayed as 0.000. In most cases, Concise Mix is preferred.
- Optional:
Click the Set as default check box to retain your choice
in future sessions.
Click OK.
