3D Line Tool
Use the 3D Line tool to connect two nodes with a straight line.
The 3D Line tool is only available if the Top view tool is
enabled.
Activate the tool and click with the left mouse button to define the starting point of the line. Drag the line to the second node and save it by clicking once again. The new line belongs to the currently active track. To modify the object parameters afterwards use the Object Properties dialog.
