Application definitions are a predefined set of instructions to describe application parameters, store responses and
prepare responses for job execution.
Add a Cluster Using SSH
Add and establish a connection to the HPC or Workgroup using SSH by registering it so that you may begin submitting and monitoring jobs.
Add a Cluster Using HTTPS
Add and establish a connection to the Access Web server using HTTPS to begin submitting and monitoring jobs.
Edit Cluster Details
Update the staging location and the central repository server address details.
Delete a Cluster
Remove a cluster when you no longer want to submit and manage jobs on that cluster.
