Setting Alerts
Set alerts to monitor the condition of an HPC cluster.
Setting an Alert for Nodes that are Offline
Set an alert so that an email is sent to a specified email address when nodes go offline.
You can set an alert for a specific node, a subset of nodes, or all nodes in an HPC cluster.
Setting an Alert for CPU Utilization
Set an alert so that an email is sent to a specified email address when CPU utilization either drops below a specified percentage and/or rises above a specified percentage at a PBS cluster.
The percentage of CPU utilization for an HPC cluster is calculated as:
Setting an Alert for when a Cluster is Unavailable
Set an alert so that an email is sent to a specified email address when a cluster becomes unavailable.
A cluster can become unavailable when the PBS Professional Server is down or if the system on which the PBS Professional Server is hosted is unreachable.
Unsubscribe from All Alerts
Remove all alerts by unsubscribing.
