Connect to an HPC cluster so that you can monitor job and nodes and configure the Workload Manager. Adding a cluster
in configure also adds them to the optional Dashboard and Node management pages.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
HPC Cluster Accessibility
Overview about HPC clusters accessibility and how Managers can grant or revoke access to a cluster.
Add an HPC Cluster
Connect to an HPC cluster so that you can monitor job and nodes and configure the Workload Manager. Adding a cluster in configure also adds them to the optional Dashboard and Node management pages.
Update an HPC Cluster
Update a cluster when you want to rename the cluster, the cluster's hostname changes, or the SSH port that the PBS Server listens on changes.
Delete an HPC Cluster
Delete an HPC cluster that you no longer want to monitor or administer.
Grant a Role Access to an HPC Cluster
Grant users assigned to a role having MonitorPBS Viewer or MonitorPBS Admin privileges access to an HPC cluster.
Revoke a Role Access to an HPC Cluster
Restrict users assigned to a role having MonitorPBS Viewer or MonitorPBS Admin privileges from accessing an HPC cluster.
