Connect to an HPC cluster so that you can monitor job and nodes and configure the Workload Manager. Adding a cluster
in configure also adds them to the optional Dashboard and Node management pages.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Managers can revoke access to an HPC cluster that has been added by a user with
MonitorPBS Admin privileges.
Users with MonitorPBS Admin privileges can add an HPC cluster. A
Manager can revoke this access to the cluster.
Once the access to the cluster is
revoked, the user cannot re-add the cluster. If the user attempts to re-add the
cluster, the message Cluster name already exists is displayed. The
cluster still exists, the user just does not have access to it anymore.
Click the Configure tab.
Click Users from
the Access Management menu located on the left-hand side of
the web page.
Click the name of the user.
Figure 1. Select User
Click Edit.
Click to revoke access to the cluster.
Figure 2. Revoke Access to an HPC Cluster
Click Save.
Access to the HPC cluster is revoked for the user and the following
notification is displayed to the user if the user is currently logged into
Control:
Your view is updated to reflect the privilege changes in cluster: CLUSTER
where
CLUSTER is the name specified for the cluster.
