Requirements for Adding an HPC Cluster
Requirements that must be satisfied to add an HPC cluster.
Once the cluster is added, subsequent administrative actions are performed as the credentials utilized while adding the cluster. It is recommended to add the cluster using the credentials of someone with PBS Manager privileges. Connecting to a cluster using non-managerial credentials will severely limit the administrative actions that can be performed, however monitoring capabilities will not be affected.
