Connect to an HPC cluster so that you can monitor job and nodes and configure the Workload Manager. Adding a cluster
in configure also adds them to the optional Dashboard and Node management pages.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Workload Manager. Adding a cluster in configure also adds them to the optional Dashboard and
Click the Monitor tab to
monitor and manage HPC cluster jobs and nodes.
Click the Configure tab
to configure an HPC cluster by changing Workload Manager settings, queues
and resources.
Click Manage Clusters.
A dialog box appears where information about the cluster is entered.
Figure 1. Manage Clusters
For Cluster Name, enter the name of the cluster as it will appear in the
Control web application.
The cluster name must be 20 characters or less.
Tip: Use the
unique name supplied during the installation of the Data Collector so that analytics data is tracked separately for
PBS Complexes having the same
Fully Qualified Domain Name (FQDN).
For Host, enter the cluster's host name by entering its:
IP address - a four-part number string such as 18.72.0.3.
Host name - a text string such as hpc.altair.com.
Click Show Advanced Options.
Figure 2. Advanced Options
For SSH Port, enter the SSH port that the machine
hosting the PBS Server listens on.
Change the SSH port if the machine hosting the PBS Server has been configured to run SSH
on a non-default port.
For Username and Password, enter the username and password of an
authenticated user on the machine hosting the PBS Server.
Once the cluster is added, subsequent administrative actions are
performed as the credentials utilized while adding the cluster. It is recommended to add
the cluster using the credentials of someone with PBS Manager privileges. Connecting to a cluster using non-managerial credentials will
severely limit the administrative actions that can be performed, however monitoring
capabilities will not be affected.
Click Add.
The cluster is added.
The following notification is displayed to any users that
have been granted access to the HPC cluster based on their role, all Managers, and
the user who added the cluster:
Your view is updated to reflect the privilege changes in cluster: CLUSTER
where
CLUSTER is the name specified for the cluster.
Click Close to close the Manage Clusters dialog
box.
If the cluster was added via the Monitor tab, then you may
now begin monitoring and managing the HPC cluster's job and nodes. If the cluster was
added via the Configure tab, then you may now begin configuring
