Job Submission Event Workflow
An overview of the events that occur once a job is submitted.
Figure 1. Job Submission Event Workflow
Submit a Job
Submit a job using the qsub -P <projectname> option so that PBS knows to track the HPC resource usage against a Project Account.
If you want to track HPC resource against a User Account, then use qsub -P <username>.
The hook uses the ncpus and walltime requested at job submission to calculate the amount of credit to assign to the job (Step 2).
Check Credit Availability
Budget Manager calculates the amount of credit to assign to a job based on the Service Unit assigned to the Account. In the example above, the Service Unit assigned to the Project Account is cpu_hours, therefore job credit is calculated as ncpus requested * walltime requested = 4 CPUs * 2 hours = 8 cpu_hours.
- The job is rejected.
- The job is placed into a queue. At run time, if there is not enough credit for the job to run, the job is returned to the queue for later consideration.
Job Completes
Once the job completes, Budget Manager determines the actual amount of currency consumed by the job based on the Service Unit assigned to the Account. In this example, the hook uses the ncpus and walltime used by the job to calculate the amount of currency consumed by the job. The currency consumed is calculated as ncpus used * walltime used = 4 CPUs * 1 hr = 4 cpu_hours.
Reconcile
The currency that was credited to the job, but unconsumed is placed back in the Account. In this example, 8 cpu_hours was assigned to the job. Only 4 cpu_hours were consumed, therefore 4 cpu_hours is credited back to the account.
