Add a Project Account
Add a project account so that allocations can be credited into the account and jobs can be run against the account.
Only an Budget Manager
administrator can add an account.
- Click the Configure tab.
- Click Projects from the Budget Manager menu located on the left-hand side of the web page.
Click
Figure 1. Add a Project Account -
For Project Name, enter a name that best represents the
project account.
Valid characters are A-Z, a-z, 0-9, underscores, dashes, period, tilde (~).
For Active, choose one of the following options:
- Click
to activate the account.
- Click
to deactivate the account.
- Click
For Accounting Policy, choose of the following options:
- begin_period
- The account is charged in the period when a job begins.
- end_period
The account is charged in the period when a job ends.
- proportionate
The account is charged in the corresponding periods when a job is run.
Enter a start date and end date for the project account:
- For Start Date, use the calendar widget to choose a start date.
For End Date, use the calendar widget to choose
an end date.
The end date must be greater or equal to the start date.
For Clusters, click on the name of an available cluster
to associate it with the account.
Tip: Use the search box to search for a cluster. To disassociate a cluster from an account, click on the name of a selected cluster.
For Users, click on the name of an available user to add
the user to the project account.
These users are able to run jobs that consume currency added to the project account.Tip: Use the search box to search for a user. To remove a user from the account, click on the name of a selected user.
For Stakeholders, click on the name of an available user
to make that user a project stakeholder.
A stakeholder can add or withdraw currency from an account.Tip: Use the search box to search for a user. To remove a stakeholder from an account, click on the name of a selected user.
Click Save.
The project is added.
