Change the Privileges of a Role Add or remove access privileges for a role. Review the default roles and privileges before changing the privileges of a role. You cannot change the access privileges of the default roles. Click the Configure tab. Click Roles from the Access Management menu located on the left-hand side of the web page. Click the name of the role. Figure 1. Edit a Role Choose one of the following options to change the privileges given to the role: Click located to the right of the privilege to enable the privilege. Click located to the right of the privilege to disable the privilege. Privileges are not mutually exclusive, so you may assign more than one. Click Save.
