Viewing the Results
View and post-process the results in POSTFEKO.
A model of the full solution (no ideal receivers or sources) is provided. The ideal receiving antenna calculates the coupling assuming a matched load. The helix antenna is loaded with its complex conjugate impedance. The power in the load represents the total power received by the antenna. Results can then be compared directly.
The coupling results are derived from the received power data. In POSTFEKO the received power may be plotted on a graph. It is also given in the .out file.
Model | Received power (mW) | Coupling (dB) | Runtime (s) |
Full model | 2.66 | -45.75 | 15 |
Far field pattern | 2.56 | -45.92 | <3 |
Spherical modes | 2.60 | -45.82 | <3 |
Near field | 2.67 | -45.73 | <3 |
For convenience results were computed over a frequency range and plotted on a graph in POSTFEKO.
