Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
  1. Set the Mesh size equal to Coarse
  2. Set a lambda local mesh size on the face of the outer dome.
    Tip: The mesh on the outer dome contributes a large portion to the total memory. Coarsen the mesh to reduce the memory requirement.
