Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Set the model unit to millimeters.
Define the following variables:
- d = 5.8 (The spacing for the periodic boundary condition.)
- h = 0.5 (The thickness of the substrate.)
- t = 0.091 (The thickness of the bonding material.)
- s1 = 0.15 (The width of the dielectric surface, bottom layer.)
- s2 = 0.18 (The width of the dielectric surface, upper layer.)
- w = 2.5 (The width of the centre metallic surface.)
- fmin = 5e9 (The minimum frequency.)
- fmax = 15e9 (The maximum frequency.)
Create the two layers for the dielectric.
Create a cuboid for the lower layer centred at the origin.
- Definition method: Base centre, width, depth, height
- Base centre: (0, 0, 0)
- Width: d
- Depth: d
- Height: h
- Label: LowerLayer
Create a cuboid for the middle layer.
- Base centre: (0, 0, h)
- Width: d
- Depth: d
- Height: t
- Label: Glue
Create a cuboid for the upper layer.
- Base centre: (0, 0, h + t)
- Width: d
- Depth: d
- Height: h
- Label: UpperLayer
Create the lower and upper PEC surfaces.
Create the upper rectangle.
- Base centre: (0, 0, h + t + h)
- Width: d-s1
- Depth: d-s1
- Label: S1
Create the lower rectangle.
- Width: d - s2
- Depth: d - s2
- Label: S2
Create the outline of the PEC surface on the bonding material.
Create a rectangle.
- Width: d
- Depth: w
- Label: L1
Create a rectangle.
- Width: w
- Depth: d
- Label: L2
Create a rectangle.
- Union the parts, L1 and L2.
- Use the Simplify transform on Union1 to remove redundant edges caused by the overlapping of two rectangles.
- Union all the parts.
Create the two dielectric media.
Create the dielectric medium, Substrate.
- Relative permittivity: 3.38
- Dielectric loss tangent: 0
- Label: Substrate
Create the dielectric medium, Glue.
- Label: Glue
Set the region properties of the two layers.
- Set the region of the middle layer to Glue.
- Set the region of the remaining two layers to Substrate.
Set the face centred on top of the Glue material to
PEC.
Figure 1. Top view of the FSS using show/hide of faces or a cutplane to show the PEC face centred on top of the glue material.Tip: Use show/hide of faces to see these faces. -
Set the large top face and large bottom face to PEC, but keep the remaining
narrow faces (which border the large top face and bottom face respectively) set
to Default or Dielectric
boundary.
Figure 2. Top view of the FSS. The top and bottom faces are set to PEC. The narrow faces around the border are set to default or dielectric boundary. - Add a single incident plane wave with θ=0° and ϕ=0°.
- Set a continuous frequency range from fmin to fmax.
