Viewing the Near Field Results (2D)
Create a new Cartesian graph. Create two near field traces and compare the Ey and Ex components of the near field along the X direction.
- On the Home tab, in the Create new display group, click the Cartesian icon.
Add the near field result to the Cartesian graph.
- On the Home tab, in the Add results group, click the Near Fields icon. From the drop-down list, select NearField1.
View the near field along the X direction.
On the result palette, in the Slice panel, make the following changes:
- From the Independent axis (Horizontal) list, select X position.
- From the Frequency list, select 1.645 GHz.
- From the Y position list, select 100 mm.
- From the Z position list, select 460 mm.
View the magnitude of the Ey component of the field.
Quantity panel, clear the
X check box and the
Z check box.
X check box and the
Z check box.
Add a second trace to the Cartesian graph by duplicating
the NearField1 trace.
- On the Trace tab, in the Manage group, click the Duplicate trace icon.
A second trace, NearField1_1, is created. -
View the magnitude of the Ex component of the field.
- On the result palette, select the NearField1_1 trace.
- On the result palette, in the Quantity panel, select the X check box and clear the Y check box.
Set the vertical axis to dB.
- In the result palette, select both traces (NearField1 and NearField1_1).
- In the Quantity panel, select the dB check box.
Modify the minimum and maximum values for the vertical axis.
- On the Cartesian context tab, on the Display tab, on the Axes group, click the Axis settings icon.
- On the Axis settings (Cartesian graph) dialog, select the Vertical tab.
- Clear the Automatically determine the grid range check box.
- In the Maximum value field, enter a value of 40.
In the Minimum value field, enter a value of
-20.
- Click OK to close the dialog.
