Setting Faces to PEC
Change the surface property of the cuboid to perfect electric conductor (PEC).
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
Create a simple model using basic geometry and transformations to familiarise yourself with model creation in CADFEKO.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
There are several options available to launch CADFEKO in Windows.
There are several options available to launch CADFEKO in Linux.
Learn to create variables, workplanes and primitive shapes. Continue by combining these basic entities and modifying their properties.
Add a wire feed to the model. As this example is only for demonstration purposes, this example does not cover the adding of a port or source to the wire feed.
Use the selection type tool to highlight an element in the 3D view.
Create an aperture (hole) in a face or region by using the subtract tool. Create the geometry to be removed and subtract it from the target part. The target is the part that is reduced by cutting away a section of the part.
Load the dielectric definition for Teflon from the media library.
Set the gobal XY workplane as the default workplane.
Create a cuboid and set the region medium to Teflon.
Change the region property of the substrate to dielectric.
Align the back face centre of the horn on the front upper edge of the cuboid.
Save the model to a CADFEKO.cfx file.
The example considers a left-handed circular polarised GPS patch antenna on a finite substrate.
The example considers the antenna placement of a GPS patch antenna on a quadcopter.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
