Viewing the Load Current
View the load current of the transmission line on a Cartesian graph.
Create a new Cartesian graph.
On the Home tab, in the
Create new display group, click the
Cartesian icon.
Add the load current to the Cartesian graph.
Add results group, click the
Loads/Networks icon. From the drop-down list, select Load1.
View the load current (in dB) versus frequency.
- On the result palette, on the Traces panel, select Load1.
- On the Quantity panel, from the drop-down list select Current.
- On the Quantity panel, select the dB check box.
Change the legend position to top-right.
On the Display tab, in the
Display group, click the
Position icon. From the drop-down list select Overlay top right.
Remove the graph footer.
Chart text icon.
- In the Graph footer field, clear the Auto check box and delete the text.
- Click OK to apply the text changes and to close the dialog.
Figure 1. The load current in dB versus frequency. -
