Validating the CADFEKO Model
During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
- Fix the settings of an item in the model that is unresolved or invalid (suspect item).
- Verify that the windscreen is defined correctly by viewing the thickness of the individual layers.
- Verify that the mesh is connected.
- Use display options to colour regions and faces according to their media.
- Use display options to highlight the relevant geometry with a specified solution method.
- Search for clashing geometry.
- Search for distorted, intersecting and oversized mesh elements.
- Use cutplanes to cut through a model to view inside the model.
