Defining an Optimisation Mask
An optimisation mask is a set of values that form a continuous line (or trace). Use a mask for specifying a specific performance curve for a requested output.
  1. On the Request tab, in the Optimisation group, click the  Add Mask icon.
  2. Specify the X and Y coordinates of the mask points using one of the following methods:
    1. Manually enter the coordinates in the X and Y text boxes.
    2. Import the values from an external (tab-, comma- or space-delimited) file by pressing the Import values button.
      Note: The import starts from the first coordinate point and overwrites any existing coordinate definitions. Changes in the external file requires a re-import of the values.
  3. Enter a label for referencing the mask in the optimisation objective.
  4. Press Create to create and close the dialog or press Add to add another mask.
    Note: The same mask can be used in multiple optimisation searches.
    Figure 1. The Add optimisation mask dialog.
