Adding a Custom Point Annotation
Add a custom point annotation to read the value and highlight a point of interest on the graph.
Select the trace where you want to read the point.
                Add a single point annotation to indicate the global maximum of the selected
                    trace.
                        On the Cartesian
                        context tab, on the Measure tab, on the Custom annotations group, click the
 Points icon. From the drop-down list, click
 Global maximum.
An annotation is added to the trace to highlight the maximum value. The annotation updates if the data changes. -
                        On the Cartesian
                Add a custom single point annotation to indicate the first local minimum to the
                    left (relative to the global maximum).
                        On the Cartesian
 Other.
Figure 1. The Configure annotation dialog.- In the Definition field, from the drop-down list, select First local maximum to the left.
 - Under Relative to, click Global maximum.
 - [Optional] Under Text, clear the Auto text check box and add the text you want displayed in the annotation.
                        On the Cartesian
 - Click Create to create the annotation and to close the dialog.
