Solution Methods per Application
A solution method is selected based on the electrical size of a problem, the geometrical complexity and available computational resources.
- Solution method is ideally suited to the problem.
- Solution method could be used, but an alternative method is better suited to the problem.
- <empty space>
- Indication that the respective solution method should not be used.
| Geometrically complex | Electrically large | |||||||
| Wire antennas | ||||||||
| Microstrip antennas | ||||||||
| Aperture antennas | ||||||||
| Reflector antennas | ||||||||
| Windscreen antennas | ||||||||
| Conformal antennas | ||||||||
| Broadband antennas | ||||||||
| Array antennas | ||||||||
| Lens antennas | ||||||||
| Radomes | ||||||||
| Antenna placement (radiation pattern) | ||||||||
| Antenna placement (coupling) | ||||||||
| Biomedical | ||||||||
| RADHAZ zones | ||||||||
| Periodic structures FSS, metamaterials | ||||||||
| Scattering with plane wave source (RCS) | ||||||||
| Scattering with localised source | ||||||||
| EMC/EMI shielding and coupling | ||||||||
| Propagation environment | ||||||||
| Cable bundle coupling | ||||||||
| Waveguide components | ||||||||
| Connectors | ||||||||
| Microstrip circuits | ||||||||
