Transitions are paths from one block to another on which the logic of the system flows. Transition from one state to another occurs when certain conditions are met. Note that you can
See Also:
Drawing a transition
Bending and moving transitions
Deleting transitions
Defining transition specifications
Determining transition evaluation order
Setting breakpoints for transitions
Triggering a transition with a guard
Logging messages for transitions
