Solid (Schelkunoff) Layer
This option defines a shield layer using the solid (Schelkunoff) model.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_sd1.png)
Figure 1. The SD - Cable shield layer definition dialog, set to Solid (Schelkunoff) definition.
- Shield definition label
- A name for the shield layer definition.
- Metallic material
- PEC
- Select this option to set the shield of the filaments to PEC.
- Material label
- The label of the metallic material (as defined in the DI card) to be used for the shield.
- Shield thickness
- Define the thickness of the shield layer.
