Double Exponential Piecewise Pulse
Define a double exponential piecewise time pulse.
- Time axis unit
- Specify the unit to be used for the time axis.
- Total signal duration ( )
- The total length of the signal in the specified units.
- Amplitude ( )
- The amplitude of the time signal.
- Pulse delay ( )
- The pulse delay is the time until the peak of the time signal envelope.
- Charge duration ( )
- The charge duration is the time from the pulse delay has ended until the signal begins to discharge.
- Charge time constant ( )
- The time that would be required to discharge the signal down to 36.8% of its full potential ( ).
- The time that would be required to charge the signal up to 63.2% of its full potential ( ).
- Number of samples
- The number of samples taken from the signal’s analytical equation.
The Fourier transform is as follows:
