Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also
provides RLC extraction and generation of SPICE-like equivalent circuits.
Flux provides a unified Material Identification tool based on the Altair Compose environment allowing to run an identification
of the coefficients required to create material in Flux.
This documentation deals with the Jython script used in Flux and allows to understand the various structures of
entities and functions, and use it in user scripts for example.
System Requirements
Before you install AltairFlux & FluxMotor2022.1, we recommend that you verify that your computer meets or exceeds the minimum system requirements.
Installation on Windows
This chapter deals with the installation on Windows of AltairFlux & FluxMotor2022.1, CDE/CSS and Flux API.
