Link regions and components: solid conductor
Solid conductor …
With regard to solid conductors, the user must carry out for each component the following operation:
- he defines a geometric terminal for each electric terminal of the M2 component (M2_PT002_1, M2_PT001)
![](Images/AssocierLesRegionsEtLesComposantsConducteurMassif1_0.jpg)
Define geometric terminals
To define the geometric terminals (associated with the imported electric terminals) of the regions of solid conductor type follow the next procedure:
Step | Action | |
1 |
In the Physics menu:
2 |
In the dialogue box Assign terminals …:
If external terminals | If internal terminal | |
select faces corresponding to the M2_PT002_1 terminal | select faces corresponding to the M2_PT002_1 / M2_PT001 double terminal | |
select faces corresponding to the M2_PT001 terminal | select the orientation line | |
→ | Realization of the electric terminal / geometric terminal link. |
Check the links
To check the links between the electric and geometric terminals follow the next instructions:
Edit the components … | to locate the components in the circuit |
Edit the electric terminals … | to identify the geometric terminals |
