Power balance (Steady State AC Magnetic application)
Introduction
In Steady state AC magnetic application, the computed physical quantities vary sinusoidally with time (at a given frequency). They are expressed by means of complex images.
The power balance allows the access to the powers dissipated by the system.
Sub-systems definition: reminder
The system comprises one or more sub-systems like the one presented in the figure below.
Computation / results
The values calculated for each of the sub-systems and for the period T=1/f:
- the dissipated powers (mean values over a T period)
Dissipated powers
For the dissipated powers, a summary of the computed quantities is presented in the table below.
Sub-system |
Losses (instantaneous) (in W) |
Internal |
Electrical |
Losses by the Joule effect (resistive components):
