Extrude points
Before starting
It is necessary to have a transformation (created beforehand) and points to be able to extrude points.
Extrude points
To extrude points:
Step | Action |
1 |
Select the points to extrude:
2 |
Activate the command *:
→ | A new dialogue box is opened. |
3 |
Fill out the fields:
4 |
Validate the information:
→ | The lines are created. |
→ | A new dialog box for the extrusion of entities of the same type is automatically opened. |
5 |
Quit the sequence:
![](Images/ConstructionParExtrusionExtruderPoints_1.jpg)
