Correction of geometric defects by type
Before starting
It is necessary to open the context for healing of CAD geometry as follows:
Step | Action |
1 |
Pass to the healing mode via the menu Geometry and click on Context healing of CAD geometry |
→ | The healing mode for geometry is activated. |
![](Images/CorrectionParTypeDeDefautGeometrique_0.jpg)
Cut line on point
To cut the line on a point:
Step | Action |
1 |
Activate the command via the menu |
→ | A dialog box Cut line ... is opened. |
2 |
Fill in the fields:
3 |
Validate the information:
→ | The line is cut into two. |
Cut two lines on their intersection
To cut two lines on their intersection:
Step | Action |
1 |
2 |
Fill in the fields:
3 |
→ | The two lines are cut. |
Extend line to point
To extend the line to a point:
Step | Action |
1 |
→ | A dialog box Extend line ... is opened. |
2 |
Fill in the fields:
3 |
→ | The line is extended. |
Extend line to line
To extend the line to other line:
Step | Action |
1 |
2 |
Fill in the fields:
3 |
Reduce continuous lines in one line
To reduce continuous lines in one line:
Step | Action |
1 |
→ | A dialog box Reduce … is opened. |
2 |
Fill in the fields:
3 |
→ | The lines are reduced in one line. |
Merge two lists of lines
To merge two lists of lines:
Step | Action |
1 |
→ | A dialog box Merge … is opened. |
2 |
Fill in the fields:
3 |
→ | The lines are replaced. |
