Explanation of results: Powers and losses
Introduction
It is necessary to give more details about the computation of different powers and losses.
Active power and Joule losses: Why?
In the steady state AC application, Flux can compute:
- the apparent power S = ModC(PowV)
- the reactive power Q = Imag(PowV)
- the active power P = Real(PowV)
- the Joule losses:
- region of coil conductor type:
- region of solid conductor type:
Question: the active power and Joule losses are they identical?
Answer: yes and no, according to the modeled case. (see following block)
Formula details
Here is a reminder of formulas in steady state AC application:
with
The first part is
mandatory a real because J* can't be complex.
But the second part can have a real part
and an imaginary part when the case is modeled with a complex
permeability:
- if ì isn't complex → active power = Joule losses
- si ì is complex → active power ≠ Joule losses
Joule losses (coil conductor)
Two possibilities to compute Joule losses of a coil conductor:
on a region:
(in steady state AC Magnetic)
(in transient
magnetic)
with RCCreg = resistance computed in function of the material and of the fill factor* associated to the region of coil conductor coil*.
on a component:
(in transient
magnetic)
with RCCcomp = RCCreg + RCCadd
where RCCadd corresponding to the resistance defined in the coil conductor
If one field is missed, the computation on region of Joule losses is « Invalid » and the computation on component of Joule losses takes into account only the RCCadd
