Isotropic / anisotropic materials
Introduction
The studied materials can be isotropic or anisotropic. In other words, the magnetic behavior of the material is as follows:
- independent of the direction of the applied field (isotropic material)
- dependent on the direction of the applied field (anisotropic material)
These two cases are presented in the following sections.
Isotropic materials
Isotropic materials are characterized by a law independent of the direction of the applied field.
The and
vectors
are always collinear.
The dependence between and
is a
scalar relationship, which is written as: D= ε .E
Anisotropic materials
Anisotropic materials are characterized by a law, which is dependent on the direction of the applied field.
The and
vectors
are not collinear.
is a
vector relationship, which is written as:
with ε permittivity tensor:
… in Flux
The model provided in Flux is a simplified model.
The vector dependence between and
can therefore be expressed in the form of three curves:
Dx(Ex), Dy(Ey),
Dz(Ez)
The permittivity tensor is then written:
