Modify a solved scenario
Introduction
It is possible (under certain conditions) to modify a solving scenario that has been solved and to resume the solving process.
Conditions for modification
The conditions to modify a scenario are presented below.
For each parameter defining the control of the solving process it is possible:
to modify or delete the last interval
(except for the 1st interval that defines the scenario)
 - to add one interval to the interval list
It is not possible to add a parameter to the list of parameters defining the control of the solving process.
Modify a scenario
To modify a solved scenario, follow the steps below:
| Step | Action | ||||||||
| 1 | Edit the scenario to be modified | ||||||||
| 2 | Choose the parameter whose control is to be modified | ||||||||
| 3 |
                         In the Parameter control zone :
| 4 | Click on Yes in the confirmation box | ||||||||
| 5 |
| 6 | Click on OK to close the box | ||||||||
| → | There is a possible deletion of results associated with the modified or deleted interval |
Resume the solving process
To resume the solving process of a modified scenario, follow the next steps:
| Step | Action |
| 1 |
                         In the Solving menu
| 2 |
                         In the box for the selection of scenarios
| → | Sequential solving of all the steps added to the scenario |
