Flux object: user guide
Overview
Before begin the description of a device, it is possible to appear the following question:
Portions (or parts) of this device can be used for the modeling of others devices?
Basic idea
If the answer is yes, the geometric building of a device can be considered as a structure in lego.
Then, the general principle of construction is as follows:
- Description of different pieces of the structure in the independent Flux projects (base lego or Flux objects).
- Construction of the complete device in a new Flux project, by means of already built bricks (Flux objects).
Geometric construction of a motor performed importing stator and rotor parts already build.
Rotor object: rotor geometry (ROTOR.FLU project) |
Stator object: stator geometry (STATOR.FLU project) |
New object: motor geometry (MOTOR.FLU project) |
Main interest: bank of objects
This type of construction presents certain constraints, but also offers the possibility to realize a bank of objects that can be used for different studies.
