Altair® Flux®  2022.1 Documentation
2022.1
  1. Home
  2. Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
  3. Geometry construction
  4. Global entities
  5. Geometric parameter
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Identification
  • Material Manager
  • Flux e-Machine Toolbox
  • Flux Examples
  • Flux in SimLab Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Parametric distribution with Flux
2022.1
  • User guide
    The user guide gives information about principles and how to use Altair® Flux® 2022.1.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    See a list of documents to understand how to use certain features.
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  • Flux Skew
    Flux Skew is a module allowing to facilitate the realization of a quasi 3D or 2 ½ D study starting from a 2D description.
  • Flux PEEC
    • Principles
    • Geometry construction
      • Global entities
        • Geometric parameter
          • Geometric parameter: about
          • Geometric parameter: definition (structure)
        • Coordinate system
        • Transformation
      • Tube Conductor mode
      • Assimilation Conductor mode
      • Import files from mechanical CAD
    • Performing a simulation
    Flux provides a unified Material Identification tool based on the Altair Compose environment allowing to run an identification of the coefficients required to create material in Flux.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
    FeMt is a application in Flux dedicated for Electric Machine which permits to compute and postprocess results like efficiency maps.
  • Flux Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
    See the lists of 2D and 3D SimLab examples using the Flux solver, with all available documents, *.slb databases and all script files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
    This document guides you through using parametric distribution with Flux.
2022.1
  1. Home
  2. Flux PEEC
  4. Global entities
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Flux Examples
  • Mementos
  • Macros
Geometric parameter
Contents
