Import formats
Import formats
The following table summarizes the different file formats accepted in Flux, associated with the type of import:
| Type of import | Available File formats | Extension | Type of format |
| geometry import called « standard » | IGES (Initial Graphics Exchange Specification) | *.IGES, *.IGS | standard |
| STEP (Standard for Exchange of Product) | *.STEP, *.STP | ||
| DXF (Draw eXchange File) | *.DXF | ||
| STL (STereo Lithography) | *.STL | ||
| FBD (Flux 2D géométrie) | *.FBD | proprietary | |
| mesh import | NASTRAN neutral | *.NAS, *.DAT | standard |
| PATRAN neutral | *.PAN, *.DAT | ||
| UNV (UNiVersel Ideas Master Serie) | *.UNV | ||
| MED (Model of data exchange) | *.MED | ||
| HyperMesh/SimLab/OptiStruct (Nastran format) | *.BDF, *.BLK, *.BULK, *.DAT, *.FEM, *.NAS, *.NASTRAN | ||
| geometry import called « advanced mode » | IGES (Initial Graphics Exchange Specification) | *.IGES, *.IGS | standard |
| SAT | *.SAT | proprietary | |
| CATIA V4 | *.MODEL | ||
| CATIA V5 | *.CATPRODUCT, *.CATPART | ||
| INVENTOR | *.IPT | ||
| PROE (Pro Engineer) | *.ASM , *.PRT |
Supported versions
The following table summarize the versions supported by ACIS R22 version (geometry kernel) for different import formats.
| Type of import | File format | Supported versions |
| geometry import called « advanced mode » | IGES (Initial Graphics Exchange Specification) | IGES versions up to 5.3 |
| STEP (Standard for Exchange of Product) | STEP AP203, AP214 (geometry only) | |
| SAT | Up to ACIS R22 | |
| CATIA V4 | CATIA 4.1.9 to CATIA 4.2.4 | |
| CATIA V5 | CATIA V5 R6 – R20 | |
| PROE (Pro Engineer) | Pro/E 16 to Wildfire 5 |
Type of accepted file
For import Flux accepts only files in text format. The binary files are not accepted.
Multiple import
Multiple imports are available. Flux is able to import the files with different formats (DXF, STL, etc) in the same project.
