Search of geometric defects by type
Introduction
The checking by defect type is the operation of research and identification of the geometric defects performed on a type of defect.
Before starting
It is necessary to open the context for healing of CAD geometry as follows:
Step | Action |
1 |
Pass to the healing mode via the menu Geometry and click on Context healing of CAD geometry |
→ | The healing mode for geometry is activated. |
![](Images/CorrectionParTypeDeDefautGeometrique_0.jpg)
Search of blocking defects (1)
To search of the following blocking defects:
- superimposed points
- superimposed lines
- intersection line-line
- intersection line-face
follow the next instructions:
Step | Action |
1 |
Activate the command via the menu and click on: |
→ | If the geometry presents defects of this type, the geometric defects are identified under the specific entities associated with them. |
Search of blocking defects (2)
- abnormal lines (of small dimension (Flux epsilon))
- abnormal faces (of small dimension (Flux epsilon))
Step | Action |
1 |
→ | A dialog box Search … is opened |
Search of non-blocking defects (1)
To search of the following non-blocking defects:
- abnormal lines (of small dimension (user epsilon))
- abnormal faces (of small dimension (user epsilon))
Step | Action |
1 |
→ | A dialog box Search … is opened. |
2 |
Fill in the field:
3 |
Validate the information:
Search of non-blocking defects (2)
- open wires
Step | Action |
1 |
Activate the command via the menuSearch open wires and click on |
