SimLab Tutorial Summary: 3D Linear Actuator
The studied device is obtained from an import, it is a linear actuator with a coil, a mobile and a fixed part.
![](Images/Summary_3D_LinearActuator_1.png)
Analysis 1: Computation of the electromagnetic force
This a 3D magneto static solution.
Visualisation of magnetic flux density, magnetic field and force curve depending on the mobile part position.
![](Images/Summary_3D_LinearActuator_analysis1.png)
![](Images/Summary_3D_LinearActuator_analysis1_ElectoForce.png)
Example access
All files corresponding to this example are accessible in the Knowledge Base in Altair community:- to follow the example step by step, the corresponding files are in
"Example_name_StepByStep" folder containing:
- Tutorial folder: contains the document describing the example step by step
- InitialFiles folder: contains *.slb databases and files needed to build the example step by step
- to play scripts and retrieve SimLab and Flux project, the corresponding files
are in "Example_name_PlayScripts" folder containing:
- ScriptsTutorial folder: contains script files to be able to play each analysis
- Input folder: contains initial *.slb databases and all necessary files to play each analysis script
- Output folder: empty (contains the obtained results after the script execution)
