Error and Warning Messages
This glossary contains generic messages generated by nanoFluidX, their likely causes, and possible methods to resolve the related issues.
Warnings will not stop the simulation, but should be investigated to ensure the success of the simulation. Errors will stop the solver immediately. This behavior can be controlled by setting wrnFailLevel in Simulation.
Important: This glossary is only valid for nanoFluidX 2022.1. The codes and messages may not match other versions.
