Altair Simulation
Altair Simulation
2022.1
  1. Home
  2. Altair Simulation Tools
    Administrative tools to customize your Altair Simulation installation.
  3. HyperWorks GUI Toolkit
    The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
  4. Utils
  • What's New
  • Altair Simulation Introduction
  • Tutorials
  • Altair Simulation Tools
Index
Altair Simulation
2022.1
Altair Simulation
  • What's New
    View new features for Altair Simulation 2022.1.
    Quick introduction to Altair Simulation products.
  • Tutorials
    Discover the functionality of Altair Simulation products with interactive tutorials.
    • Altair License Utility
      The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted Altair Units.
    • Altair Compute Console
      Altair Compute Console (ACC) is a utility that allows you to start different Altair Simulation Solvers.
    • Remote Job Submission
      Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
    • Remote Server User Guide
    • AbaqusODB Upgrade
      AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2017 (or earlier) to Abaqus 2022.
    • HvTrans
      HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
    • HyperWorks GUI Toolkit
      • Base Widgets
      • Compound Widgets
      • Dialogs
      • Miscellaneous
      • Utils
        • hwtk::image
        • hwtk::settings
      • Validation
        The -validate, -validatecommand, and -invalidcommand options are used to enable entry widget validation.
      • Specify File Patterns
      • Write a New Custom Widget
        Steps and examples for writing a custom widget using the toolkit.
    • HyperWorks Cleanup Utility
      The HyperWorks Cleanup Utility is a script for Windows that removes any custom settings that you may have due to HyperWorks.
    • Model Identification Tool
      The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
    • Register HVPcontrol
      Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
    • HgTrans
      HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
    • HyperWorks Automation Toolkit
      The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
    • H3D Validation Tools
      The H3D Validation Tools available in HyperWorks are H3D Info and H3D Validate.
    • Uninstall
      Use the Altair Simulation Products Uninstaller to remove all files from the installation directory.
View All Altair Simulation Help
Altair Simulation
Altair Simulation
2022.1
  1. Home
  4. Utils
  • What's New
  • Tutorials
Index
Utils
  • hwtk::image
  • hwtk::settings
