HS-1710: Simple Optimization Study
Learn how to optimize a simple function defined using a Templex template.
The base input template defines two input variables, DV1 and DV2, labeled X and Y, respectively. The objective of the optimization is to minimize X + Y with the constraint 1/X + 1/Y – 2 < 0.
Run Optimization
Post Process Results
In the Post-Processing step of an Optimization approach, you can access additional tools to review the results. Use the Integrity, Distribution, and Scatter tabs to compare and analyze designs.
