In this tutorial, you will learn how to complete an Area function and create an input template from a Radioss file using the HyperStudy - Editor in HyperStudy.
Learn how to perform a shape optimization using HyperMesh and HyperStudy. You will be using the finite element solver Abaqus, and HyperMorph to do the shape parameterization. This tutorial also demonstrates how to solve a problem when HyperMesh and HyperStudy are running in Windows and the solver is on a UNIX platform.
Learn how to set up a mesh refinement study using a SimLab model to investigate the relationship between the SimLab mesh parameters and max Stress and max displacement.
HS-1550: Shape Optimization Study Using HyperMesh and Abaqus
HS-1610: Set Up a SimLab Model using JavaScript
HS-1620: Set Up a Flux Model
Learn how to set up a Flux model in HyperStudy that will investigate the relationship between actuator dimensions and the mechanical force output.
HS-1670: Set Up a RADIOSS Model
This tutorial demonstrates how to parametrize an input deck via HyperMesh and subsequently set up a Radioss model in HyperStudy.
HS-1680: Set Up an OptiStruct Model OptiStruct simulations can be directly integrated into HyperStudy without any pre-processor such as HyperMesh.
