HV-6000: Creating Measures for an FEA Model
In this tutorial, you will learn how to view the minimum and maximum values of results applied, create a measure group, and plot a measure created.
- To create a Measure, right-click in the Results Browser and select Create >
Measure from the context menu.
Figure 1. - To edit a Measure, select it in the Results Browser to see the properties in
the Entity Editor.
Figure 2. - To display the Measure, click on the icon
next to the measure in the Results Browser.
- To hide a displayed Measure, click on the icon
Measures allow you to measure the distance between nodes, position of coordinates, relative displacement, relative angle, and angle between nodes. Measures also allow for the measuring of nodal and elemental contour values. See the Measure panel for additional information.
