pltIBuildPlotsCtrl SetRequestFilter
Sets the Y request filter.
pltIBuildPlotsCtrl_handle SetRequestFilter request_filter
HyperWorks Tcl Modify
This command sets the value in the Y request filter. The filter removes Y requests from the Y request list that do not match the filter value.
request_filter
The string that you want to use as a filter. All Y Requests that do not have this string within it will be removed from the Y Request list.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetRequestFilter "UPPER";
Keywords
HyperWorks
Tcl
Build Plots
Modify
Filter
