pltIBuildPlotsCtrl SetSubcase
Sets the subcase.
pltIBuildPlotsCtrl_handle SetSubcase subcase
HyperWorks Tcl Modify
This command sets the subcase (from within the subcase list). If there is nothing in the subcase list, then nothing can be set as the subcase. You can find what the subcase list consists of with the GetSubcaseList command.
Note: The command GeneratePlot must be called after to draw the plot with these changes.
subcase
A string with the value of the subcase that you want.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetSubcase "Time";
Keywords
HyperWorks
Tcl
Build Plots
Modify
