Exercise 1: Introduction to User Subroutines
In this exercise you will learn about user subroutines and run a model for a single cylinder engine.
- The curve is read from a CSV file, and gives a force value based on the angular displacement of the connecting rod.
- The output returns the displacement magnitude of the piston.
- The force entity uses the angle of the connecting rod and the curve to apply a variable pressure force to the piston.
- The motion entity applies an angular motion to the Crank_Grnd revolute joint.
- The default damping of the system is 1, however it can be changed in the Bodies panel.
Entity | Usrsub | Description | |
Curve | SPLINE_READ | Reads the curve data file. |
Request | REQSUB | Outputs the requested values. |
Force | GFOSUB | Applies a force on the system. |
Motion | MOTSUB | Applies a motion to the system. |
Damping | DMPSUB | Defines the damping of a flexbody. |
Run the Model
In this step, you will run the model to obtain the results files to compare with your usrsub results.
Click the
(Run) button.
From the Run panel, click
(Open File) to browse your <working directory>. Specify the name of the MotionSolve XML file as engine_baseline.xml.
Click
to check the model for errors.
- Click the Run button.
