OS-E: 0120 Nonlinear Static Analysis with Hyperelastic Material Model, under Compression Loading and Unloading
Behavior of hyperelastic material during loading and unloading phases. Typical examples include rubber mounts, boot seals, and rubber keyboard domes.
![](../../../images/solvers/hyperelastic_mat_compression_load_unload_fe_model.png)
Figure 1. FE Model
Model Files
The model file used in this example includes:
HYPERELASTIC.fem
Model Description
- FE Model
- Element Types
- CHEXA
- Steel Material
- Young’s Modulus
- 2.1E5 MPA
- Poisson's Ratio
- 0.3
- Density
- 7.8E-9 Tonne/mm3
- Elastomer Dome Material MATHE
- Model
- MOONEY
- NU
- 0.495
- C10
- 0.482
- C01
- 0.12
- D1
- 0.0166
Results
![](../../../images/solvers/hyperelastic_mat_compression_load_unload_results.png)
Figure 2. Element Stress Plot and Total Displacement with Loading and Magnitude
