OS-E: 0020 Inline-4 Engine Head
The structural analyses of a cylinder head under various loading conditions can be accomplished by means of finite element analysis using OptiStruct. The results, combined with each analysis concerning the different operating processes of the engine, can be separated mainly into two parts.
Figure 1. FE Model
The capacity of gasket sealing mainly depends upon the pre-stressing of the bolts, which are the source of the maximum external loading on the inner structure of the cylinder head.
The location of the weakest contact pressure on the raised portion of the gasket can be transferred as a result of the effect of thermal stress or strain, which may cause the increase in pressure and escaping of the gas.
Model Files
The model file used in this example includes:
NLSTAT_ALTAIR_PWT.zip
Model Description
- FE Model
- Element Types
- CHEXA
- MAT1
- Young’s Modulus
- 21500 MPA
- Poisson's Ratio
- 0.3
- MGASK
- Direct Tensile Modulus
- 0.001
- Transverse Shear Modulus
- 12000
Figure 2. Details of the Boundary Condition and Gasket Material Loading and Unloading Curve
- Assembly Loadings
- The major percentage of the loading applied to the engine is the assembly loading. This mainly refers to the pre-stressing of the bolts, and it plays an important role in preventing gas from escaping from the internal part of the engine.
- Thermal Loadings
- In the case of thermal loadings, the nodal temperatures resulting from the prescribed
thermal analysis are assigned to all corresponding nodes of the FEM model of the second
cylinder head in order to calculate the thermal stress/strain of the cylinder head
structure.
Figure 3. Gas pressure
- Case 1
- Assembly Loadings
- Applied pretension loading (41.25 KN) in head bolts
- Case 2
- Thermal Loadings
- Lock pretension displacements
- Case 3
- Gas Pressure
Results
Figure 4. Subcase 1: Displacement Contour
Figure 5. Subcase 1: Stress Contour
Figure 6. Subcase 1: Gasket Pressure and Sealing Status
Figure 7. Subcase 2: Displacement and Stress Contour
Figure 8. Subcase 2: Stress Contour
Figure 9. Subcase 2: Contact Pressure Contour
Figure 10. Subcase 3: Displacement Contour
Figure 11. Subcase 3: Stress Contour
Figure 12. Subcase 3: Bore Distortion Graph of 4th Cylinder (Calculation Using SimLab)
